View Poll Results: Which one first?
LCAs
13
59.09%
Aluminum Driveshaft
9
40.91%
Voters: 22. You may not vote on this poll
Aluminum driveshaft or LCAs first? Your vote counts!
Trying to decide on doing either LCAs or an aluminum driveshaft. The driveshaft right now isn't to bad but there is some vibrations, and it does get pretty bad over 80-85mph under acceleration. On the other hand I would like to be able to drop the clutch for some decent 60ft. times at the track. I already have Nitto DRs and a stage 2 clutch, but I still cant hook to well. It seems like LCAs should help a bit from what I have read/heard. So what do you guys think, what first?
Aaron
Aaron
Do you get wheel hop? If so, spring for the control arms
IMO, I would get a Denny's shaft....to many breakage problems with the alum shafts.
I have a set of Spohn LCA's and Panhard in the for sale section if your interested.
well the drive shaft will make the car more enjoyable on the rare occasion that you cruize at 80+ mph...
the lca will help you every time you launch and also during cornering
so what do you want? comfort or speed?
I never really had many problems as far as wheel hop, its just the tires spin and then hook up, or I bogg down on the line. Always one or the other. I was pretty set on the LCAs but now Im thinking since I do a lot of highway driving and the car is mostly a daily driver...I might go for the driveshaft first.. thanks for all the replys!
Aaron
Aaron
Aluminum DS. My stock steel DS killed my rear driving at 90 one day with only 25k miles on the car due to bad vibration from it. If you drag race it much I would go with the 1LE over the LS1 if you're deciding between the two, thats what I got.
