Alternator squaking...can i fix it?
Old Apr 20, 2003 | 09:28 AM
xxsaint69x's Avatar
hey guys, my alternator squakes a bit..it charges ok etc, so i dont really want to buy a new one. Is there a way to fix the squak? Can i take the whole thing apart? Wha should i use to clean it inside? Oh yeah...how the heck do i remove the nutt that hold the pully on the alternator..its a big *** nutt, and its on there very tight
Old Apr 20, 2003 | 10:20 AM
ROCKN SS's Avatar
Are you sure that it is your alternator and not the belt?
If so you might try these guys http://www.alternatorparts.com/ to see if they have a rebuild kit for our alternators.
The easiest way to remove the pulley nut is with an impact wrench, otherwise you are going to have to find some way to hold the pulley (maybe one of those strap wrenches).
Old Apr 20, 2003 | 10:25 AM
fbird95's Avatar
If it is the alternator and not the belt, you could try tapping the outter casing of the alternator with a hammer. Sometimes this will move it just enough to stop the noise. Dont drive it home, but a few good taps may fix it. However, i dont recomend this method, and dont blame me if it messes something up. I would take the alternator off to see if it actually was the alternator itself turning and not the belt.
Old Apr 20, 2003 | 10:28 AM
xxsaint69x's Avatar
already tested it..its the alternator itself
hmm ill try it with da humma
zFrank
Aug 12, 2015 03:46 AM
MikeWhitener
Aug 2, 2015 06:17 PM
gelbza
Jul 12, 2015 08:10 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
colts0455
Jul 7, 2015 07:19 PM
