Alternator relocation installed pics
Old Apr 4, 2006 | 07:03 PM
  #16
ajschult's Avatar
Re: Alternator relocation installed pics
Originally Posted by ibanez6rg
I don't think I can justify paying $200 for a few brackets and a belt.
The only reason to get this bracket is if you check your valve lash often, cleaning up the engine bay is just a bonus. $200 is worth it to me because it is a pita to take the alternator off everytime you want to take the passenger side valve cover off IMO.
Old Apr 4, 2006 | 08:25 PM
  #17
dreamer1q's Avatar
As I said, this will be my third year running the first one made. I have had NO slippage and the only problem I have had was the case screws on the alternator vibrated loose. I put a dab of loctite on them and have been good ever since.
Old Apr 4, 2006 | 08:28 PM
  #18
ibanez6rg's Avatar
That is me, but I'll keep taking the alt. off until something cheaper ever comes around if it does.
Old Apr 6, 2006 | 05:55 PM
  #19
Gearhead6s's Avatar
i need this bracket to mount my alt down low so my manifolds can come over it for the turbo. i would use something like th espeed specialty stup but the belt is still in the way and i don't have anything to run but the alt.
Old Apr 6, 2006 | 07:21 PM
  #20
Projectz28's Avatar
Moderator
here is another one if you want to change to a CS130 alternator. bottom of the page and its only $60...
http://www.alangrovecomponents.com/LT1.htm
Old Apr 6, 2006 | 11:07 PM
  #21
97formulakid's Avatar
I can have my alternator off in about 5 min or less. I mean its only 3 bolts and two connectors. I think it would be cool to relocate it to clean up the engine bay, but for now I think 5 min of work is worth way more than 200 bucks. Just my .02.
Old Apr 7, 2006 | 12:22 AM
  #22
DIYAR21's Avatar
dude it looks like it is too high.. you cant close your hood.. alos that thing looked like so different.. just for 60 bucks?? but l guess to install would be pain in the ***..
also someone please send me some pics of regular alternator removal and installations. l am about to replace mine!!
thanks..
Erdal
Old Apr 7, 2006 | 12:32 AM
  #23
ibanez6rg's Avatar
Scroll down...
Old Apr 7, 2006 | 06:14 AM
  #24
Projectz28's Avatar
Moderator
thanks..
Erdal
scroll down to the bottom of the page. You are looking at the wrong one...
Old Apr 7, 2006 | 06:21 AM
  #25
Honda Hunter's Avatar
Very intresting. That's way better than paying the rip off prices everyone else wants.
Old Apr 7, 2006 | 05:59 PM
  #26
Gearhead6s's Avatar
i looked into the alan grove one but i don't know anything about a CS130 alternator and i saw no reason to replace the goos stock one that i have.
Old Apr 7, 2006 | 07:01 PM
  #27
amean94ta's Avatar
does the other altnator plug into the factory connection?
Old Apr 7, 2006 | 07:22 PM
  #28
Projectz28's Avatar
Moderator
I belive the plugs are the same on the 2 alternators. Actually the fan and pully spec out that same but you need the cs130 due to the mounting brackets. The stock alternator has tabs for mounting at 12 and 6 o'clock. the cs130 in the picture does not.
Old Apr 7, 2006 | 08:30 PM
  #29
thesoundandthefury's Avatar
The factory plug is compatible with the CS130. I'm getting a custom accessory setup put together using this style alternator and it checks out ok.
Old Apr 7, 2006 | 08:58 PM
  #30
amean94ta's Avatar
well **** if it fits and plugs in $60 is a screaming deal
