Alternator question/charging question
Old Nov 9, 2004 | 12:11 AM
lt1camaroman93's Avatar
My alternator is not charging the system at all, I was wondering if the wire going into the clip was unpluged could cause this problem? If so, what does that wire do? I think that it is just a signal wire to show the regulator the voltage but i could be way off.
Old Nov 9, 2004 | 01:03 AM
Red_94Formula's Avatar
Re: Alternator question/charging question
That wire tells the alt how much power to make. If it is uppluged then no power, as in your case.
Old Nov 9, 2004 | 08:31 AM
Thanks. Thats what i thought, i just wanted to make sure.
Old Nov 14, 2004 | 03:07 PM
madwolf's Avatar
Phil called me the other day and asked me about this. I looked in the wiring diagrams and this wire goes inside the car through the c220 connector.
Here's a picture of the 220 connector.
The alternator wire is RED as you can see in the picture.
Just run a wire from your alt to that connector and you should be fine. The connector should be under the carpet on your passenger side near the rubber grommet in the firewall.
EDIT: He told me you guys tried shorting something. Hopefully you didn't kill the alternator.
Old Nov 14, 2004 | 04:02 PM
cool, thank you. I did kill one alt, but it was really old and had bad bearings anyway. The one i bought has a lifetime warranty so if i killed this on i will just get another one. I will run that wire there later this week and see whats up. Thanks a lot.
Old Nov 14, 2004 | 10:14 PM
The purpose of the little red wire is to turn on the voltage regulator. It is run through a 470 ohm resistor in the cluster assy.
Old Nov 15, 2004 | 12:03 AM
Thanks again guys. Off subject, shoebox how in the world do you have 16k posts???
Old Nov 15, 2004 | 08:20 AM
Ken95Z28's Avatar
Whatever you do, do not plug the exciter wire directly to 12v you will kill the alternator voltage regulator. It has to go through the resistor as described by Shoebox.
Old Nov 15, 2004 | 08:24 AM
Eff's Avatar
Eff
Magic. Duh!
Red97LT1
Mar 1, 2015 05:08 PM
Gtpguy
Jan 26, 2015 04:50 PM
HectorM52
Jan 16, 2015 10:21 AM
Hurin
Dec 13, 2014 07:38 PM
nophix
Nov 30, 2014 10:26 PM
