Alternator noise
Old Jul 26, 2012 | 10:09 PM
chrisv256's Avatar
Alternator noise
I've warrantied two alternators since I had my engine replaced a month ago. My mechanic didn't replace the rear L bracket on the back of the alternator and now I keep going through alternators because of bearing noise. Is this because of the bracket being missing or just bad luck?
Old Jul 26, 2012 | 10:27 PM
mrmint69's Avatar
Re: Alternator noise
There is one thats slightly bent and around seven inches long. I never used mine and have no issues. Does the alternator move some or feel very solid? There should be almost no play and the belt should be very snug. If cheap remanufactured, it is always a possibilities.
Old Jul 26, 2012 | 11:41 PM
chrisv256's Avatar
No play. Everything is tight and doesn't move.
Old Jul 27, 2012 | 08:58 AM
mrmint69's Avatar
Can you put the bracket back? I changed designs and need different bracket. Ebay sells them if you need to buy one.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
