alternator lead?
Old Nov 8, 2004 | 09:24 AM
DavidNC's Avatar
alternator lead?
My 97 lt1 wiring diagram shows tha a brn (or red) wire goes from the alternator to the PCM. With the alternator in plave, I cannot locate the lead. Anyone know where it is on the alternator?
Old Nov 8, 2004 | 09:41 AM
madwolf's Avatar
Re: alternator lead?
There's a rubber boot protecting the connection. It should be behind the alternator, just look carefully.
Old Nov 8, 2004 | 10:15 AM
DavidNC's Avatar
I see the thick red wire going to the battery leading from the back of the altnernator. I also see a socket marked "Bat" on the back of the altnernator, but no wire.
Old Nov 8, 2004 | 10:27 AM
madwolf's Avatar
Here you go.
Old Nov 8, 2004 | 11:05 AM
DavidNC's Avatar
Yes, I clearly find that wire. The wiring diagram show a second wire (brn or red) going to the instrument cluster (the v6 goes to PCM first), then back to the fuse block as a pink wire. This is the one that I can't locate.
Old Nov 8, 2004 | 12:13 PM
madwolf's Avatar
That other one has a connector with a retaining clip. I do not have the picture for it, but it should be on the bottom of the alternator in the back. Sometimes it's hard to find. I'll see if I can find a picture of it later.
Old Nov 8, 2004 | 12:18 PM
DavidNC's Avatar
Ion,
Thanks, that was enough of a description. It is hard to find, but it has been found.
David
Old Feb 28, 2005 | 10:07 PM
Z06Z28's Avatar
I'm bringing this post back from the dead.
I know this sounds stupid but I'm stuck and need a permanent fix. Alternator red lead wire accidently got caught on the Alt pulley and broke. What guage wire is that, 8ga or 6ga? Well, I can't find 8-6ga Anywhere, even butt slices and eye round terminals I cant find which is odd. I've tried pepboys, hardware stores, stereo shops, autozone, kragens, you name it..this sux. All the stuff I found is for stereos and mostly all the wire stuff is up to 10ga. Seems like my only option at the moment is to run a $5 4ga Batt cable from the Alt to Batt terminal. So...is it alright to do this, I dont see why not but then again I'm not electrically inclined?
Thanks.
Old Feb 28, 2005 | 10:59 PM
Bigger won't hurt, but don't go smaller. It's an 8 gauge wire.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
gelbza
Jul 12, 2015 08:10 AM
