alternator keeps blowing out
Old Oct 21, 2004 | 02:33 PM
george0924's Avatar
i have got about three bosch refurbished alternators on about a month... Other there crap or something is making them short out. anybody got any ideas????
Old Oct 22, 2004 | 09:23 AM
slopokrodrigez's Avatar
Re: alternator keeps blowing out
The first thing we recommend to people is that they change the belt and the tensioner if they had not already done so when they change the alternator. A bad bearing in the tensioner can cause a jerky motion to the tension on the belt that keeps loading and unloading the alternator shaft. Most of the time this leads to a mechanical failure but once in a while, we see an electical failure.
Second, does your battery seem to have a large draw on it when everything is turned off? One way to tell, is to pull a cable and use a meter to measure current.
Do you have one of those Big Thumping Amps? If so, I'de put money on that being the cause.
With the engine running, measure Voltage across the battery, it should be around 14 VDC.
Dave
Old Oct 22, 2004 | 11:35 AM
transram97's Avatar
what should your peek amps be with the car running?
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
