Alternator Going Bad?
Old Jul 22, 2006 | 09:44 PM
EviLBoX's Avatar
Is there a way to test if my alternator is on its way out? Lately I've noticed my battery gauge dipping below 13v while sitting at a stop light and hovering around 13v while cruising. My battery was 4.5 yrs old so I bought a new one today, but the voltage is still dipping kinda low. My thoughts are the alternator is on its way out, but I can't be sure. What do you guys think?
Old Jul 22, 2006 | 11:54 PM
HardcoreRM125's Avatar
Re: Alternator Going Bad?
Get a Voltmeter and check the V on the battery with the car running. You should have at least say 13V for it to be charging right. From what Ive seen at the garage, GM cars always charge stronger than other ones. Its not uncommon for GM cars to charge at 13.7-14.0V ... And its its not at at least 12.8-12.9, its not charging strong enough. Check to make sure you have clean connections on the alt. and battery terminals.
Old Jul 23, 2006 | 06:06 AM
Guest47904's Avatar
Guest
You can't go by the gage. If you notice what the gage reads when you have A/C and lights on, you would think the engine was off.
Incidentally, the reading across the battery should be 14V or over when the engine is running.
Old Jul 23, 2006 | 08:20 AM
EviLBoX's Avatar
Thanks guys, I'll check it out today.
Old Jul 23, 2006 | 08:23 AM
user 647483's Avatar
Most autoparts stores will test your battery and alternator while it's still
in your car for free. Some can even test additional items (staters, PCM codes, etc...)
Old Jul 23, 2006 | 11:27 AM
MeanGreen97Z's Avatar
Autozone will test it free.
Old Jul 23, 2006 | 11:32 AM
matLT1's Avatar
I get the same thing when it is hot anbd I have a lot of accessories on. This has been going on for ywo years now (since I bought the car). As said above you can have your alternator tested and the battery tested but from the way you have described things, this is typical with the charging system for our cars.
Old Aug 13, 2006 | 11:44 AM
EviLBoX's Avatar
I had my battery and alternator tested at Autozone, both checked out fine. I guess I just won't worry about it.
Old Aug 13, 2006 | 06:33 PM
Red_94Formula's Avatar
They can still check fine when tested, but if the voltage it less then 13 its not charging as much as it should be. Should be ok for a little while, but if it gets lower over time think about replacing it.
You can take apart the alt and check out the condition of the brushes and their contacts. if the contacts are a little uneven / not smooth or excessive wear of one of the two brushes then that means its soon time to rebuild the alt or replace it.
Old Aug 13, 2006 | 08:07 PM
EviLBoX's Avatar
He said the voltage was 14v when he tested it, that's where it should be I believe.
Old Aug 14, 2006 | 12:11 PM
TobyZ28's Avatar
I was having the same "issue" as you. Long story short, I replaced the alt and the voltage is identical to the way it was before. Basically a waste of $$ if your not having any problems.
eanhl2004
Apr 4, 2015 12:01 PM
Red97LT1
Mar 1, 2015 05:08 PM
dale3in98
Feb 14, 2015 12:18 PM
Gtpguy
Jan 26, 2015 04:50 PM
HectorM52
Jan 16, 2015 10:21 AM
