Alternator Getting Hot Hot
Ok I got the 14-gauge big blue wire from Relay running to water pump the wire coming from water pump has a 20-amp fuse. The small blue 18-gauge wire I got going to EGR Sednoid. Is it the trigger wire. I got the 14-gauge red wire from relay going to AUX on circuit breaker. Then the other side of circuit breaker It says BAT and I have it going to the Battery +. When I turn the key on the water pump runs. I started the car let it run for about a minute 4 or 5 times in about a 10-minute span and the Alternator got hot hot Check the new Pictures my son posted yesterday. Thanks, Happy Thanksgiving
Re: Alternator Getting Hot Hot
You really need to add a signature after all these years.
https://www.camaroz28.com/forums/lt1...nature-879835/
