Alternator Cutoff
Old Oct 23, 2003 | 11:26 PM
Black Cloud's Avatar
Alternator Cutoff
As a former NHRA Stock Eliminator racer we used to put an alternator cutoff switch in the car.After the burnout you cut it off and after you cross the finish you flip it back on.
Can this be done on a 94 LT1 and if so which wire do you put the switch on?
Thanks,John
Old Oct 23, 2003 | 11:36 PM
Probably the small wire for the "exciter" and gauge. It uses voltage on that wire to tell the regulator to turn on. If you were to put a switch on the output (cable going to the battery), the alt would probably burn up due to trying to provide too much voltage to an open connection.
I don't take responsibility for what might happen in either case. You might want some more opinions.
Old Oct 24, 2003 | 08:48 PM
Anybody with any info?
Thanks,John
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Thirim
Jul 30, 2015 01:29 PM
