Alternator Bracket pics, Dont know what bolts go where.
Old Aug 27, 2003 | 07:36 PM
OBDIICamaro's Avatar
Ok does anyone know since I wasnt the one who took this apart, do you guys have like a front view pic? I know what holes obviously I just need to know what size bolts to use where.
Old Aug 27, 2003 | 08:27 PM
Scotts94z28's Avatar
If I remember correctly you have several bolts that require a 14mm socket and one the requires a 12 mm socket. Most if not all are different lengths as well. So without a pic just narrow things down. I believe that the longest one goes right at the top of the alt. the support bracket behind the alt gets two of the short bolts(although I discarded my bracket years ago) So find two short bolts that I think have a 14mm head, not find the corresponding holes in the back of the alt and on the intake. Now if memory serves me right, you should be down to three bolts. One long one with a nut on the back(I think that might be your 12mm head)about 3 to 4 inches long with a nut to tighten up the back side. The other two I think are short with a 14 mm head. The nut the tightens the hot wire down has a 13 mm head.
Sorry I had to go by the size of the head/hex, not that familair with metric thread pitch's.
Old Aug 27, 2003 | 09:54 PM
Im actually talking about how the bracket mounts. The whole huge thing.
Old Aug 27, 2003 | 09:58 PM
96z's Avatar
96z
Are you refering to the whole accessory bracket?
Old Aug 27, 2003 | 10:09 PM
Accessory bracket
Alternator mounting
Old Aug 27, 2003 | 10:24 PM
kingman109's Avatar
i love that website.... has saved me sooooo many times whoever put it together gets my praise
Old Jul 30, 2005 | 04:48 AM
Black1995Z's Avatar
Re: Alternator Bracket pics, Dont know what bolts go where.
Anyone have a pic of the backside of thier alternator? I forgot what goes where.
chris_duperre@***.net
Also, which and what wires go to the starter and where do they bolt?
Old Jul 30, 2005 | 07:59 AM
Alternator rear.
Starter. Positive battery cable goes on the bottom and purple wire to outside small lug.
Old Jul 30, 2005 | 11:45 AM
Black1995Z's Avatar
Originally Posted by shoebox
Alternator rear.
Thanks Shoebox, I looked on your site first but I guess I missed the first one.
So only the one wire connects to the alt?
On the starter, it looked like there are three studs. Is the purple wire attached to the harness?
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
maybe2fast
Mar 16, 2015 09:45 AM
Jlo
Feb 3, 2015 09:41 PM
HectorM52
Jan 16, 2015 10:21 AM
