Alternator Bracket pics, Dont know what bolts go where.
Ok does anyone know since I wasnt the one who took this apart, do you guys have like a front view pic? I know what holes obviously I just need to know what size bolts to use where.
If I remember correctly you have several bolts that require a 14mm socket and one the requires a 12 mm socket. Most if not all are different lengths as well. So without a pic just narrow things down. I believe that the longest one goes right at the top of the alt. the support bracket behind the alt gets two of the short bolts(although I discarded my bracket years ago) So find two short bolts that I think have a 14mm head, not find the corresponding holes in the back of the alt and on the intake. Now if memory serves me right, you should be down to three bolts. One long one with a nut on the back(I think that might be your 12mm head)about 3 to 4 inches long with a nut to tighten up the back side. The other two I think are short with a 14 mm head. The nut the tightens the hot wire down has a 13 mm head.
Sorry I had to go by the size of the head/hex, not that familair with metric thread pitch's.
Re: Alternator Bracket pics, Dont know what bolts go where.
Anyone have a pic of the backside of thier alternator? I forgot what goes where.
chris_duperre@***.net
Also, which and what wires go to the starter and where do they bolt?
Starter. Positive battery cable goes on the bottom and purple wire to outside small lug.
Originally Posted by shoebox
Alternator rear.
So only the one wire connects to the alt?
On the starter, it looked like there are three studs. Is the purple wire attached to the harness?
