Alternator
Old Jul 31, 2010 | 10:51 AM
summers_Z28's Avatar
Alternator
hey guys.. kinda feel dumb asking.. but my alternator finally went out last night.. so i went online to look at the costs of a remanufactured alternator.. only problem is i have no idea how much amps i should select. the choices they givin me are
100-119
120-129
140+
Old Jul 31, 2010 | 11:24 AM
n2ceptor's Avatar
1993 had 124amp 94+ was 140amp ....
Old Jul 31, 2010 | 11:34 AM
ok, thank you.
Old Jul 31, 2010 | 12:39 PM
DCL94Z28's Avatar
Early 94's used 124 amp
Late 94's used 140 amp
Check the RPO sticker on the inside of your glove box door. I have a KG9 code on the sticker of my 94 Z28.
KG9 = 140 amp
KG8 = 130 amp
KG7 = 125 amp
I can't find a code for the 124 amp. I assume it's KG7.
Old Jul 31, 2010 | 12:51 PM
old93camaro's Avatar
cant he use anyone he wants i think they all have the same connector
Old Jul 31, 2010 | 01:13 PM
n2ceptor's Avatar
The connectors are different.. You just have to get a pigtail....
Old Jul 31, 2010 | 01:21 PM
ok sounds good think i need to upgrade as well
Old Jul 31, 2010 | 02:02 PM
Pretty sure the small wire connector to the dash is the same.
Old Dec 29, 2010 | 10:48 PM
ZZ's Avatar
ZZ
Re: Alternator
I know this is an older post, but I figured I'd add this for folks who actually search for stuff. I did the 140A alternator swap on my 93 today and ran into a little snag that I didn't read about when I search originally. The lower bracket in the rear of the alt that goes to the manifold stud was too long. I used an AC Delco Alt. Maybe I got one that was an oddball, i dunno. I just shortened it, reflattened it, drilled it, and made it work. Anyone else run into this before?
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Thirim
Jul 30, 2015 01:29 PM
