is this alright to do this to my headers
Old Mar 25, 2008 | 11:01 PM
djexotic08's Avatar
in the summer i am gettin a hooker's long tube headers (2231HKR) that have heat treaded paint. but i want to wrap him. is that ok?
Old Mar 26, 2008 | 04:52 AM
2000GTP's Avatar
The general feeling surrounding header wrap is to leave it off.
Old Mar 26, 2008 | 05:27 AM
What exactly will your headers be coated with? What is "heat treated paint"? You need a cera-metallic (e.g. - JetHot, Airborne, etc.) coating. It will reduce heat loss through the tubes, increasing performance, reduce underhood temperatures, and reduce corrosion and stress cracking. There is no "paint" that will provide those benefits. If you have the cera-metallic coating, you don't need a wrap.
Wrapping headers increases the rate of corrosion due to the extreme tube metal temperatures, increases cracking at the welds, and may increase the risk of fire.
Old Mar 26, 2008 | 07:10 AM
djexotic08's Avatar
thanx, i didn't know know. and the headers from hookers well cost around $439 plus shipping from summit racing. and they are cera-metallic coated.
Old Mar 26, 2008 | 07:46 AM
caldercay's Avatar
And to further this - header wrap will void most header manufacturer warranties.
Old Mar 26, 2008 | 09:59 AM
96supersport's Avatar
Header wrap is also known to hold in moisture,basically helping your headers rust, increasing the chances of exhaust leaks.
Old Mar 26, 2008 | 10:15 AM
No.... they don't hold in moisture. How could a piece of fabric operating at 1,000*F contain moisture?
The wrap increases the rate of tube metal oxidation (= rust) because it holds the mild steel at such a high temperature (virtually equal to EGT), the iron starts to combine with the oxygen in the air.
Old Mar 26, 2008 | 10:33 AM
Well thats what i ment to say
Ive always heard they held in moisture though, like if it gets hot then cold, wouldnt you get condensation between the metal and the wrap?
Kinda like if you go outside and its 80 degrees, you shoot your rifle and few times and put it in your car with the a/c on. the gun starts to "sweat"
Old Mar 26, 2008 | 10:45 AM
95firehawk's Avatar
That it will do. It won't contain any moisture while you're driving it but it will however "trap in" condensation as you park it for the evening. Doesn't help either way.
Old Mar 26, 2008 | 11:00 AM
Since the wrap is holding the tube metal temps above the ambient air temp for a period, when you shut the engine down, it not likley that they will suddenly sub-cool below the dew point, allowing moisture in the air to condense out. Trust me.... when you heat cheap mild steel to 1,000*F it starts to rust.
Old Mar 26, 2008 | 08:31 PM
djexotic08's Avatar
well, is it ok to put a extra coat of that stuff on my headers or just leave it be!
Old Mar 27, 2008 | 08:37 AM
Originally Posted by djexotic08
in the......... but i want to wrap him. is that ok?
What "stuff"? An extra coat of header wrap? Only if you don't agree with what was stated above.
Old Mar 27, 2008 | 11:46 AM
ss.slp.ls1's Avatar
Just leave it be.
Old Mar 28, 2008 | 12:51 AM
djexotic08's Avatar
i'm just trying to limit the heat in the engine bay.
Old Mar 28, 2008 | 03:19 PM
NJ-LE's Avatar
Smile
djexotic08:
I don't know if it snows down where you are, but a serious problem with header wrap is driving where the DOT salts the roads when it snows. The water is driven out of the wrap by the heat but the dissolved salts remain to cause chloride cracking in metal and absorb water from the air when the humidity is high. I'm wrapped, with no problems, but the car is only driven on clean, dry roads.
