almost have $15,000, please review project
#16
Re: almost have $15,000, please review project
Thanks for the replies, i do understand that i will be spening another $6-8000 on drivetrain and the the ptk hot parts and whatnot, but i will be tackling that later on in the project, for right now i am mostly concerned with just the motor and it's related components.
thanks for the link on the shop, i never planned on assembling the bottem end myself as mentioned in the post.
Does anybody know a good priced high volume oilpump?
I didn't think the quote for the heads was that bad..
new castings, springs, valves, retainers, rockerarms, custom cam, lifters, pushrods, ported intake, and timing set all for 3,400 didn't seem too bad i thought... and nesides, this way i can re-use my LT1 intake instead of having to buy and LT4 with the AFR's.
I shop around some more.. does anyone have any better suggestions on a larger cam... I don't mind a lope at all on the street, just need to pull enough vaccum for the brakes and idle under 1000rpms and not rev past 6,200.
thanks for your time guys.
#17
Originally Posted by rskrause
Lots of things to comment on. But to start, the cam is too small to make that much hp, IMHO. Also, the head flow may not be enough, even with 16-18psi.
Rich
Rich
Or head volume and cross section....
That's a biggie with the air density that you are looking at in a blown motor.
The more you cool the charge the denser it gets so it's even more of an issue.
Bret
#18
so your saying that the 68cc cc chamber and 210 intake runner port is not big enough?? I am confused why it would be so hard to make 750rwhp with 18psi. there are plenty of bone stock ls1 running 11psi making 600-650rwhp with stock flowing heads and a stock cam. I figures with 275cfm, 383ci, larger cam, and 7psi more i could up that number by AT LEAST 150hp? See my reasoning? am i missing something or have i been mis-informed?
thanks
thanks
#19
thanks
thanks
Rich
#20
thanks
thanks
Bret
#21
you will need to go alot higher than 6200 to make that kind of power....
any of the setups listed can easily turn 6500 or more. get good lifters and a forged crank.
are you talking about running this motor N/A until you can afford a turbo setup?
i doubt it would even run with 8.5cr and a turbo cam. mabye with some major tuning but it is not a good idea.
