Almost Failed Inspection (High speed)
Old Apr 2, 2006 | 02:22 PM
neil350's Avatar
Exclamation Almost Failed Inspection (Low speed)
The High speed did not change much at all but the low speed did to the point where it almost failed. I havent really driven that car more than 2500 miles in the last year. Here are the results from 2005 compared to 2006.
Low Speed Results
April 2005 - 66,510 Miles
HC (PPM) Standard 117 Current Reading 15
CO (%) Standard 0.65 Current Reading 0.01
CO2 (%) 14.8
O2 % 0.4
NOx (ppm) Standard 879 Current Reading 441
Dillution (%) >6 14.8
April 2006 - 69,074 Miles
HC (PPM) Standard 117 Current Reading 108
CO (%) Standard 0.65 Current Reading 0.36
CO2 (%) 14.9
O2 % 1.0
NOx (ppm) Standard 879 Current Reading 213
Dillution (%) >6 15.3
Old Apr 2, 2006 | 02:45 PM
neil350's Avatar
Re: Almost Failed Inspection (High speed)
Edit: There machine also broke midway through the test, so it did sit for a good 15 minutes.
lt1matt
Mar 21, 2015 07:35 PM
dluna333
15
Mar 13, 2015 12:30 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Bob_Ricco
Jan 27, 2015 11:44 AM
