All those with electric wp....
Old Dec 29, 2005 | 04:58 PM
nb 96 z's Avatar
How did you guys wire your water pump? What do I need and what do I do? Is there a best way? Thanks.
Old Dec 29, 2005 | 07:50 PM
nb 96 z's Avatar
Re: All those with electric wp....
what kind of relay did you use?
Old Dec 29, 2005 | 09:11 PM
turbo_Z's Avatar
I used the pink ignition wire in the fuse box to energize the relay. Then I grounded it to the body right above the driver side head lights... youll see a ground already there I believe so I just put mine in the same spot. The power to the pump I pulled from that power junction inside the red box by the battery and also used that ground junction in the same area to ground the pump. After all that I put a 10 amp inline fuse leading from the power junction to the relay. The relay I used was a $5 standard relay from Autozone. And if you want it to look really clean then wire everything up inside the fuse box with the other relays. Its a chore but it looks great... only real hard part was finding the correct terminals to crimp onto the wires for that factory look.
Old Dec 30, 2005 | 11:01 AM
nb 96 z's Avatar
Thanks guys.
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
