are all TH700-R4 transmissions the same?
Old Apr 20, 2003 | 06:59 PM
sc93's Avatar
i.e. the same physical size?
I am wondering if a 700R4 from an 89 chevy 1500 work truck would fit in my 93 Camaro Z28. I found one for sale for a good deal. I plan on changing out the converter to a 2800 or 3000 stall, new governer, possibly a shift kit, .500 main boost valve, vette servo, etc...
This should work, right?
Old Apr 21, 2003 | 02:47 AM
Pro Built Automatics's Avatar
First make sure the transmission fluid is in good shape, and make sure there is no blcak soot on the bottom of the pan. Second you will need to change the tail section & speedometer gear setup. Third put in the .500 main boost valve, .296 intermediate/reverse boost valve, Corvette servo, and the Trans-Go Performance Shift kit. Let me know if you have any questions or if I can be of help?
Old Apr 21, 2003 | 06:13 AM
TedH's Avatar
Yep. You need a tailshaft from another fbody.
Old Apr 21, 2003 | 08:18 AM
sc93's Avatar
I can use the stock tailshaft off the tranny in the car now, right?
Just swap them out?
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
