With all this talk about spark plugs lately
Old Apr 16, 2004 | 09:27 AM
Tim240z's Avatar
I'm using a set of Champions, anyone else using them? Any known issues? Should I switch to the NGKs or are these OK?
Tim
Old Apr 16, 2004 | 11:02 AM
stereomandan's Avatar
If your gas milage is o.k., you have a smooth idle, and no misses in the upper RPM's, then I would stick with them.
Did you gap them to 0.050"?
Dan
Old Apr 16, 2004 | 11:07 AM
Tim240z's Avatar
They are gapped to FSM specs, but I have been battling with an 'off the line' stumble and bad miss, but higher RPM and cruise is fine. I think the stumble is my injector(s), since I have replaced EVERYTHING related to the ignition system.
Tim
Old Apr 16, 2004 | 11:14 AM
Plugs can cause some funky stuff to happen.
You could try the NGK's. For $20, it's worth the try.
Also, I would clean your MAF if you have not done so already. It smoothed out my car BIG TIME when I did it. I had not cleaned it in about 55k miles, since I bought the car new. When I cleaned it, I could not believe how smooth the engine reved.
Be careful.
I used electrical contact cleaner that I got from Autozone, and a Q-tip. Spray the MAF elemant very good, as well as the q-tip end and VERY GENTLY rub the build up off the MAF sensors and everything else on the MAF sensor.
Dan
Old Apr 16, 2004 | 11:27 AM
Tim240z's Avatar
I may try just unplugging the MAF and driving the car and see if the stumble is still there...just to eliminate the MAF as a possible element..
here is the whole story:
http://web.camaross.com/forums/showt...hreadid=239654
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
