All of the sudden the car won't idle?
Old Jun 21, 2003 | 05:27 PM
96speed's Avatar
Above 1500 rpms, the car revs up w/o hesitation. Below 1500, the car chokes down to 4-500rpms until it catches and goes back up to 1500, or it just dies- this cycle repeats until the car dies.
Plugs are new, wires should be good (have 10k on them, never missed a beat), fuel pressure is good, opti is 3 weeks old, coil is new, ignition module is new.
Anyone have an idea? What am I missing?
EDIT: No DTC codes, but I threw both a high res and low res code last week at the same time . Likely the opti, but need someone to remind me how possible it is for the opti to die.
Ryan
Old Jun 21, 2003 | 06:51 PM
97 RedSS's Avatar
Does it still have the same power throughout the rpm range? Sounds like you have a sensor going south on you and the iac is trying to compensate for it..Make sure your MAF is not letting air in or have a leak anywhere letting unmetered air into the TB..
Cody
Old Jun 21, 2003 | 07:17 PM
neil350's Avatar
Ryan, was it doing this before or just start? Last time I saw the car at Hooters it idled fine. Sounded like a animal
Old Jun 21, 2003 | 08:03 PM
96speed's Avatar
Well, did a little testing. Unplugged the MAF and it runs fine.
But, while the MAF is plugged in it reads fine on the Scanmaster, just won't idle.
It looks like the MAF is really dirty, so I am going to try cleaning it and seeing it that helps.
I just want to thank Chris Boui for all his help and patience on my car. Thanks, Man!!!
Old Jun 22, 2003 | 07:37 PM
Finchinater's Avatar
Definately check the IAC. It's amazing how that little thing will effect you air intake. If the spintle is sticking then it could be closed when it needs to be opening. That's the easiest check I think.
Then definately check for TB leaks.
IAC is about $100 from GM and about 15 minutes work
later
Old Jun 22, 2003 | 10:04 PM
96speed's Avatar
Update - cleaning the MAF had no real impact. However, unplugging the MAF makes the car run fine. I will be using a different MAF this week to make sure that is the cause of my grief.
Ryan
Old Jun 22, 2003 | 10:33 PM
96z's Avatar
96z
Yeah Ryan sounds like your MAF. Those damn things can be a pain in the ****!
Old Jun 22, 2003 | 10:36 PM
96speed's Avatar
Darn right PDM!
It makes it all worthwhile when you doodoo on a Mustang tho .
Old Jun 23, 2003 | 01:17 PM
Y2K2Sierra's Avatar
No problem man. I try my best. I just expect the same in return. When my car needs more mods I know you'll be there!!
Old Jun 23, 2003 | 01:57 PM
96speed's Avatar
Talking
No sweat dude!
I just noticed something - Your car is a hardtop AND it doesn't have ttops? Sweet!
Old Jun 23, 2003 | 05:07 PM
Y2K2Sierra's Avatar
No sweat dude!
What are you talking about?????
bfmv13trivium
Jan 14, 2015 09:57 AM
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
