Are all Header gaskets the same?
Old Aug 21, 2003 | 01:54 PM
stang_killa94's Avatar
Do i need a specific gasket for my edlebrock headers or are the gaskets the same?
Old Aug 21, 2003 | 02:35 PM
TTT
Old Aug 21, 2003 | 02:46 PM
EviLBoX's Avatar
I would think "D" port shaped gaskets would be the best since that's the shape of the LT1's.
Old Aug 21, 2003 | 02:47 PM
Z95m6's Avatar
Percy's Dead Soft Aluminum header gaskets are the way to go. Get some Stage 8 locking bolts too.
Old Aug 21, 2003 | 02:53 PM
KGRESOCK's Avatar
I also like the dead soft aluminum gasket's although I'm
using the Earl's. Best header gasket I've ever used.
Old Aug 21, 2003 | 02:57 PM
Where can i buy the gaskets? You think they have them like at autozone or pep boys?
Old Aug 21, 2003 | 03:06 PM
94formulabz's Avatar
No, but you can get the felpros there. Many people use the felpros with success.
I used Copperseals at first but the raised crush area overlapped with the ports on my slp headers and therefore didn't seal completely where there was a crease created at the overlap/nonoverlapping location. They made a good seal, no significant audible ticking, but upon removal you could see black soot from leakage. I believe the AL gaskets operate the same way and have a raised area intended to be crushed down. Chances are they would work fine but to avoid the potential problem of the port overlapping and not crushing that part as designed i would recommend the felpros. You can get them anywhere vs ordering the copper and AL ones and they are cheaper too.
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
