All Hail The Mighty Arp Header Bolts!!!
Old Apr 28, 2003 | 11:21 AM
  #16
ryker77's Avatar
I used header studs 12 point head. I had to make my on wrench. The hooker headers don't have any extra room so a closed end wrench was cut to make a larger open end style wrench.
Old Nov 20, 2003 | 10:04 AM
  #17
BitCypher's Avatar
ttt
I just switched from the standard 7/16" bolts to the ARP hex-head 3/8" on my Jet-Hot LTs and FINALLY, I'm able to tighten all of my header bolts within minutes with just a deep-well 3/8" 1/4 drive socket and 3/8" open-end wrench! No more cussing and throwing tools.
Old Nov 20, 2003 | 10:25 AM
  #18
T/A#4's Avatar
One thing not mentioned; Get the 1" long ARP bolts not the 3/4" .
Old Nov 20, 2003 | 11:01 AM
  #19
Don 97 SS's Avatar
Ditto, this advice. Frankly, I can't understand the popularity of the 3/4" size. My ARP 1" bolts have held tight for nearly 5 years with no loosening or gasket leaks.
Old Nov 20, 2003 | 11:50 AM
  #20
IslandZ's Avatar
http://www.go-breslin.com/Splitlock.html
When I do my header I plan on going with these, they seem to be the best of both worlds. 12 point and locking.
Maybe a little expensive but well worth the non leaking gaskets.
Old Nov 20, 2003 | 12:27 PM
  #21
magius231's Avatar
I did the 3/4 on mine, after all this time I still have yet to have a leak. I don't check them but once a month or so when I remember it, and they are never loose.
Old Nov 20, 2003 | 03:36 PM
  #22
95 Silver TA's Avatar
Which one would you guys recommend over the other (for those really tight areas) for my Grotoyhann Long tube headers and Why?
ARP 5/16 12 point header bolts??
or
ARP 3/8 hex header bolts??
And what Length should I go with.
Thanks for any input,
Claude
Old Nov 20, 2003 | 03:38 PM
  #23
All_Z_Way's Avatar
My stage 8's are great with my Edlebrock shorties. No problems except the last one one the drivers side. Got it from the bottom. The rest I can do foom the top with a 1/4 ratchet.
Old Nov 21, 2003 | 07:33 AM
  #24
or
Claude
Any one have any input? Which you think is better and why?
Thx,
Claude
Old Nov 21, 2003 | 07:51 AM
  #25
Javier97Z28's Avatar
Moderator
I couldn't be happier with my stage 8's I love the allen key option for tightening them, and they never get loose on me anyways. I didn't use the locks either, didn't care to go through that pain in the ***.
Old Nov 21, 2003 | 09:21 AM
  #26
bradpreece95z28's Avatar
or
Claude
I may be second guessed, but I would, and DO use the
Old Nov 21, 2003 | 09:31 AM
  #27
Why is that? Is it that much smaller and better clearance wise?
Thx,
Claude
Old Nov 21, 2003 | 09:37 AM
  #28
I have good enough clearance on some of the primaries that i can actually get a socket on them
I used to have the 3/8 hex head, I hated them with a passion.
I could never get a good turn on them without having to reposition my wrench numerous times.
With the 5/16, I can get almost a full turn without any probs. FWIW, my primaries are 3/4, Dynatech headers. It may be different on other brands of headers(clearance). I just wnated to share my opinion/experience with you. Hope I have given you the information you are after.
Brad
Old Nov 21, 2003 | 09:39 AM
  #29
Brad
Thanks Broh...Thats exactly what I wanted to hear.
Claude
  #30
Anytime man:thumbup:
