Alarm wont stop going off!!!!!
Old Sep 14, 2003 | 04:29 PM
Cmr0z28's Avatar
whenever I lock my car using the keyless entry remote, 5 seconds later the alarm goes off and starts beeping. I made sure all the doors are closed, rear hatch is closed, hood is shut. any suggestions?
Old Sep 14, 2003 | 04:53 PM
pennys58's Avatar
Mine was doing the same thing. When the door was open it didn't go off, but as soon as it closed it started to go off. My battery connections were loose and causing it to go off, so check that out and make sure the terminals are tight.
JOHN
Old Sep 14, 2003 | 05:21 PM
Cmr0z28's Avatar
thanks.....any other suggestions anyone?
Old Sep 14, 2003 | 05:26 PM
1996 | Z28 SS's Avatar
I had the same problem after I got a heavy downfall of rain. Just wouldn't shut up. But then it fixed itself... never did figure out what did that
Trevor
Old Sep 14, 2003 | 05:30 PM
Cmr0z28's Avatar
lol nope, hasnt rained today
Old Sep 14, 2003 | 05:38 PM
Cmr0z28's Avatar
this is really pissing me off......I just went outside to check everything again and it's still doing it
Old Sep 14, 2003 | 05:59 PM
pennys58's Avatar
Leave the drivers side door open and press the little "button" on the inside of the door panel and set the alarm...see if it goes off. A fuse could be shorting or a wire may be cut and causing a delayed short. I don't know...I was just glad it was the battery for me.
Old Sep 14, 2003 | 06:05 PM
Cmr0z28's Avatar
Ok my car is on drugs......I went outside, opened the door, sat inside with the door opened, locked it with the keyless entry, unlocked it with the keyless entry, then closed the door, locked it with the door switch, unlocked it with the keyless entry, then locked it with the keyless entry and it stopped beeping.......lol
thanks guys
Old Sep 14, 2003 | 06:50 PM
Cmr0z28's Avatar
GOD DAMNIT NOW ITS DOING IT AGAIN!!!!!! someone please help!
Old Sep 14, 2003 | 07:01 PM
Cmr0z28's Avatar
shoebox?!!??! heeellllllpppppppp
Old Sep 14, 2003 | 09:02 PM
Cmr0z28's Avatar
I adjusted the shock sensor, now it's fine.
IndyZman
Oct 22, 2015 02:17 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
4586
Sep 27, 2015 01:55 PM
KYWes
Sep 26, 2015 08:49 AM
mark0006
Sep 14, 2015 12:35 PM
