Airfoil fit in 58mm TB?
Old Apr 28, 2004 | 08:37 PM
wytblur's Avatar
I have a BBK 58mm TB and I wnt to get an airfoil before I go to the dyno on Wed. Will an airfoil fit in the larger TB, or is it made just for stock?
Old Apr 28, 2004 | 08:44 PM
Mike383LT1's Avatar
air foil
i also have a bbk 58 mm tb never seen a air foil for one ive looked at holley,slp and acell
Old Apr 28, 2004 | 09:40 PM
wytblur's Avatar
so are you saying that holley might make and airfoil for one?
Old Apr 28, 2004 | 09:47 PM
Eddie95Z28's Avatar
Any aftermarket throttle body will have an "airfoil" built in unless it is a stocker rebored to 52mm...
94formulabz's Avatar
First off I don't have a BBK 58 in front of me.
The BBK 58mm TB is cnc machined from aluminum. It is not a bored out stock TB (AFAIK no 58mm is). BBK should have and likely did include an integrated airfoil into their design. There is no need for an airfoil on anything but a stock or TB or stock bored to 52mm TB IMO.
-brent
Old Apr 28, 2004 | 09:48 PM
Eddie beat me to it, i'm too slow....
Old Apr 28, 2004 | 09:49 PM
RedHottG2's Avatar
If I'm not mistaking, the 58mm TB has it built into it so that it has the same effect as if you bought an AF for it.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 26, 2015 08:34 AM
