AIR tube removed, need help w/ plug
Old Jan 13, 2008 | 07:12 PM
BigBadBlack93Z's Avatar
I've been out of the lt1 game for a long time and I can't find any of my old help links. So hopefully there's some help to be found here.
I just picked up a 94 Z and the previous owner has removed the emissions tubes from the manifolds and left the holes open. Before this burns a hole in the hood or starts a fire I would like to plug them. Any info on thread size or fittings to use would be appreciated. I would assume I can just get a male pipe plug and put that directly into the manifold. but what size?
Thanks, and its good to be back.
Old Jan 13, 2008 | 07:20 PM
mitchntx's Avatar
I do not recall the size, but I found mine at O'Reillys
Old Jan 13, 2008 | 07:26 PM
wish there was one around here that stocked hardware. i have an advance, autozone and an oreilly's 1/2 store.
It wouldn't even be an issue if there was a sears hardware or an ace around i'd just buy all the ones that look close for 20 cents each and go from there.
I need the part size so i can go in grainger and get one, they aren't as fun/easy to deal w/.
Old Jan 13, 2008 | 07:43 PM
raroz28's Avatar
i got mine at a local true value hardware store.
Old Jan 14, 2008 | 10:42 AM
Here's the follow up:
M22 x 1.5
Old Jan 14, 2008 | 10:49 AM
It's the equivalent of a 22mm oil drain plug. Part #1016M on this site:
http://www.cgenterprises.com/magneti...ugs/metric.htm
Same size was used in the Cummins Diesel used in the Dodge pickups, so you could find them at a Dodge dealer, probably at a premium cost.
Note that this size only works for the single-cat manifolds. The dual-cat manifolds have a smaller thread.
HectorM52
Jul 30, 2017 11:46 AM
David Dorris
Jan 17, 2015 08:10 PM
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
