air temp sensor: why is it not threaded???
I have a Vortec TB elbow that has a threaded hole which I thought holds the air temp sensor but I bought a brand new one from GM and it has no threads. What gives?? Is there another one from a different car I need?
Originally posted by madhatter
Read the directions that came with the elbow
You need to take a die(I believe 1/2") to it and thread it. Or you can do what I did and put a plug in the elbow and relocate the IAT.
If you are using it in a pressure application, you should consider upgrading to a threaded sensor. It's a pretty standard thermistor. You could get them in the downloadable MoTeC catalog. Look at page 32 for air temp sensors.
squarehead
01-15-2015 07:02 PM
95chwagon
01-13-2015 09:19 PM
