AIR system Exhaust Leak
Old Aug 10, 2005 | 02:31 PM
TobyZ28's Avatar
Question AIR system Exhaust Leak
http://shbox.com/1/diverters.jpg
See upper left picture.
The elbow going up from the header appears to have an exhaust leak right at the fitting point.
How should I go about fixing this? Do i need to replace the pipe? Could this be why I failed emissions?
Old Aug 10, 2005 | 03:06 PM
Re: AIR system Exhaust Leak
If you have a leak in the metal tube between the exhaust manifold and the black check valve, it could have affected emissions. Under some flow conditions, the exhaust gas will pull air in through the leak, and dilute the exhaust. That fools the O2 sensor into thinking its running lean, and the PCM adds fuel to that bank of the engine, causing it to run excessively rich.
You need to find a way to temporarily plug the leak, until you can get a replacement pipe.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
95chwagon
Jan 13, 2015 09:19 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
