AIR pump removal ???'s
Old Jun 26, 2006 | 12:25 PM
Wicked 97TA's Avatar
I did a search on removing the AIR pump and really couldn't find the clear cut answers I need right now.
1. I have a '94 Trans Am, by removing the entire AIR pump assembly is it gonna set off and SES light?
2. What is the best way to get the metal tube that connect the AIR pump to the manifolds? And will it hurt anything to remove it?
Old Jun 26, 2006 | 12:28 PM
Re: AIR pump removal ???'s
No SES light or code on an OBD-I 93-95, as long as you have a good fuse in the AIR pump circuit.
Most people cut the pipe to the passenger side in the middle, right under the timing cover.
Old Jun 26, 2006 | 01:01 PM
By a good fuse in the circuit do you mean the fuse that is in the car already?
Will it hurt anything to remove the metal line on the AIR pump system?
Old Jun 26, 2006 | 04:11 PM
fastchevy's Avatar
When you remove the metal pipe that goes to the passengers side, you'll need to remove a support bracket. If you have A/C it's nearly invisible, but it's there.
Old Jun 26, 2006 | 05:31 PM
Badazz94TA's Avatar
what is the advantage of this and how does it effect emmissions????
Old Jun 26, 2006 | 05:39 PM
JimboManJones's Avatar
The advantage is it cleans everything up alittle better and theres no hoses running all over the place. Maybe if your hardcore, its alittle weight reduction.
It affects emissions by not pumping fresh air into the cat causing it not to warm up as fast and a cat is most efficent when warm, cold they don't work as well.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
