AIR pump removal - relay needed?
Old Oct 23, 2003 | 08:28 PM
Cmr0z28's Avatar
Hi, my friend has a 1997 TA, and the previous owner removed the AIR pump. Should he remove the AIR pump relay?
Old Oct 23, 2003 | 08:30 PM
madwolf's Avatar
No, leave it there. Might find a good use for it later.
Old Oct 23, 2003 | 08:32 PM
crAzy95z28's Avatar
yes remove all hoses that go to the air pump also and you also have to take off the check valves that sit on top of each header and replace it with a 22mm oil drain plug i think, and just plug up the last vacum hose that connects to the intake on the side, and then plug up your vacum line on your cai if you have one...i pluged mine up with a cork!!! lol...lemme know for n e mroe qeustions!!
Old Oct 23, 2003 | 08:33 PM
madwolf's Avatar
He asked about the relay.
Old Oct 23, 2003 | 08:37 PM
crAzy95z28's Avatar
ooo the relay under that relay box (black box under the hood) if so yea leave that in or else your SES light will come on!!!
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Jan 13, 2015 09:19 PM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
cmdeshon
Dec 27, 2014 10:06 AM
NED4SPD
Sep 16, 2002 10:45 PM
