Hotcam with blower guys
Old Oct 23, 2003 | 08:03 PM
Kuma's Avatar
Hey guys I'm trying to start planning out a blown 396 stroker over the next few years, probably a procharger D1 running around 15-20lbs. I know a lot of guys say to run a blower cam but I've also heard good things about the hotcam in regard to blowers, and that's what I'm running now on my NA. Any experiences, good or bad? Note that at this time I'm not looking for *advice*, ie "use a blower cam," but experiences.
Thanks,
Rob
Old Oct 23, 2003 | 08:38 PM
95TA8280's Avatar
If you're going with a blower, why would you use a hot cam, which is an extremely mild cam? I would think you would want a more agreesive cam to maximize the boost.........
Old Oct 23, 2003 | 08:40 PM
drewstealth's Avatar
If your gonna put all that work into that your car then i would fork out the extra money and get yourself a nice blower cam to acomidate(don't think it's spelt right) the blower.
Old Oct 23, 2003 | 08:45 PM
Josh-'04 GTO's Avatar
This topic has been covered several times. It's not the Hotcam's duration, or even lift, that disqualifies it as a good blower cam. It's the lobe separation. A good blower cam will have appox. 114-116 degrees of lobe separation. 112 (hotcam) is too tight, and will allow your hard earned boost to blow right out the exhaust.
No one is saying you can't use it, or that you can't get decent numbers. It's about doing it right and maximizing your combo.
Old Oct 23, 2003 | 09:00 PM
RamAir95TA's Avatar
Yep. You'll notice that all blower grinds use a lobe seperation of no more than 114LS. The 112LS on the hotcam makes it less than ideal for use with forced induction.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
InfernalVortex
Jan 17, 2015 09:35 AM
WildRidez
Jan 16, 2015 03:10 PM
Red97LT1
Aug 7, 2002 05:45 PM
