Air Pump Question Please Help!!
Old Jan 31, 2004 | 07:37 AM
ZDUDE's Avatar
How exactly does the air pump work? I am installing a procharger and I wanted to know if I can remove the air pump all together or will I suffer some problems in the long run? and if I remove the airpump how can I prevent a check engine light?
thanks in advance.
Old Jan 31, 2004 | 09:53 AM
ibanez6rg's Avatar
The A.I.R. pump only runs on a cold startup, to help heat up the cat/cats more quickly.
I've taken mine out, along with tons of other people on the board and haven't had any prbolems.
Old Jan 31, 2004 | 12:31 PM
Re: Air Pump Question Please Help!!
thanks in advance.
You might want to mention what year your car is, because removing the pump on an OBD-II (96/97) car will require some PCM programming to prevent a code and an SES light. This is not an issue on the earlier OBD-I cars.
Are you simply concerned about the "space" issue with the blower being mounted in that area?
Old Jan 31, 2004 | 12:55 PM
ZDUDE's Avatar
Sorry forgot to mention it is a 95 OBD1. The instructions say to reroute the air pump but I just wanted to delete it completely and not have problems.
Old Jan 31, 2004 | 12:58 PM
ibanez6rg's Avatar
In that case you'll PCM won't throw any codes and you'll have no SES light that will pop-up.
Old Jan 31, 2004 | 01:01 PM
Quick96Z's Avatar
not to steal your thread or anything man, but what exactly is required to remove the air pump?? I want to get rid of mine also. I have a 96 OBD II, and when i have ion re-programming my computer for my ported heads and cam, can i have him delete the air pump so i can just toss that ugly looking, complicated p.o.s.
thanks
trav
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
