air pump question...
Old Sep 15, 2003 | 04:31 PM
ninetythreez's Avatar
what is it? what does it do? how to get rid of it? I live in a state with NO Emissions testing. I already have no catalytic converter. I am into performance, not smog pumps. (I only drive the car once or twice a week, so i am not a big polluter for all you liberal whiner tree huggers out there.)lol
Old Sep 15, 2003 | 04:39 PM
rocmemphis's Avatar
Most people just take it out when they install headers but you can do it anytime you want. Basically if I am correct it just injects the exhaust manifolds with air so the catalytic convertor(s) heat up and work faster. Since you dont have cats then your air pump does nothing. All you do is unplug it, pull it out, remove air fitting hoses on top of exhaust manifolds and plug the holes. You will have to plug the hole in the intake with a plastic plug you can get at a hardware store.
I believe thunder racing sells the air hose blockoff bolts.
Old Sep 15, 2003 | 06:27 PM
so if i wanted to order headers, a 94-95 header would work if i did away with the air pump? right? 93 specific headers are hard to find and $$$.
Old Sep 15, 2003 | 07:05 PM
Mr.Whitey's Avatar
If you don't care about the emissions just get the Jet Hot or Hooker long tubes w/o the fittings. They will fit 93-97.
Old Sep 15, 2003 | 09:29 PM
Bud M's Avatar
It blows a little air into the exhaust to help the cat burn any unburnt fuel. It does not affect performance.
Old Sep 15, 2003 | 09:39 PM
jasons93z's Avatar
I removed mine for the HUGE weight reduction......2lbs . No really i just removed it because i made a custom CAI and didnt feel the need the drill a hole on the intake so i pulled the air pump. But i do like the better access to the plugs that i got from removing it
Old Sep 15, 2003 | 11:48 PM
so tell me..what all is involved in removing it. I am gonna get some headers soon. I don't have a catalytic converter on my car anymore. My exhaust is all off-road. I don't use it as a daily driver. weekend toy mainly. I am going for all out performance. Heck, it doesnt even have a radio in it! Its my 1LE wanna be.lol.
So let's get the AIR pump off...?? It is gonna be one of those ongoing budget project cars.
Old Sep 15, 2003 | 11:52 PM
anasazi's Avatar
unplug air pump
unbolt air plug
get vacuum caps from discount auto to plug the hole in the intake
i would leave the metal piping in place however, huge pain in the *** to remove and it makes a nice zip-tie mount on the passenger side for spark plug wires when you put the headers in
no need to remove the pump however until you install headers, it affects performance not at all.
Old Sep 16, 2003 | 07:14 AM
David A. Wilks's Avatar
Does it throw any code if not plugged in? Will the SES light come on? If not, then I will remove mine just on general Principle.
One more Government Mandated part GONE!!
Old Sep 16, 2003 | 08:05 AM
anasazi's Avatar
it won't set an SES light in OBD-1 cars.... which your 1995 should be.
however just leave it in, it doesn't hurt anything and it'll just be a pain in the *** making sure the holes in the stock manifolds arn't leaking. that government mandated part is plugging potential exhaust leaks
Old Sep 16, 2003 | 09:45 AM
You are right... the government is less a pain in the **** than potential exhaust leaks.
I should buy headers!! Thats what i will do!!
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
