Air Pump question...
Old Aug 19, 2003 | 04:24 PM
  #16
drewstealth's Avatar
No it just makes more open space under the hood which is nice.
Old Aug 19, 2003 | 04:40 PM
  #17
Originally posted by drewstealth
"The Air pump is not electrical.. It does not turn on and off. It's on when the engine runs as it is belt driven. Also it is not used to warm the cats.. The Air Pump simply injects air into the exhaust pipe before the oxidizing catalyst to help in the oxidation process of harmful exhaust emissions.
If you remove it you can bet that emissions will go up some. And like I said it's on all the time.. Not just when you start it up.
Hope this helps."
That description is also correct for the 3rd Gen F-Body AIR system.. it was belt driven, ran all the time, and there was a diverter valve that fed fresh air into the exhaust manifolds at startup to heat up the cats. After the cats were warmed up, it diverted the flow to a pipe on the rear chamber of the cat, to allow the cat to oxidize HC's and CO. It ran all the time. The cat had two distinct sections... a reduction system to get rid of NOx, and an oxidizing system to get rid of HC and CO,
The 4th Gens switched to a cat that does not require a seperate air feed to oxidize the HC's and CO. So, they changed the way the AIR pump operated, making it electric, and piping it ONLY to the exhaust manifolds, to heat up the cats on startup.
Old Aug 19, 2003 | 04:49 PM
  #18
K, thx injuneer. It all makes sense now. I didn't know there were 2 sections. I'll let him know that. I guess he will have to keep it untill he smogs his car then it can go since he is gonna remove his cats.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
