air pump fuse?
Old Jun 3, 2006 | 08:56 AM
nervekiler's Avatar
air pump fuse?
hey guys snooping around my engine compartment yesterday and noticed the air pump fuse thats under the hood, 20amp, was blown. so i replaced it only to have it blow again as soon as i started the engine.
what exactly does the air pump do? and is it something that i need working when im driving? just wondering if i should make this a priority to fix or if its really not a big deal.
thanks
Old Jun 3, 2006 | 09:14 AM
Re: air pump fuse?
The AIR pump runs for a couple minues at startup. The extra air in the exhaust manifolds helps burn the rich-start fuel the leaves with the exhaust. The heat generated by burning the excess fuel in the exhaust system helps the cat(s) heat up faster. They don't work until they are hot. After the first couple minutes, its not used.
There is a "recall" on the 95 and newer LT1 AIR pumps. Dealer will replace it for free, and add a few odds and ends.
No big deal if it doesn't operate. The reason the fuse blows is because exhaust leaks back into the pump, the water condenses and the pump rusts up, drawing excessive amps. Unplug the harness connector from the AIR pump, put a new fuse in the circuit, and the SES light will go off (only works on OBD-I 93-95).
Old Jun 3, 2006 | 10:03 AM
nervekiler's Avatar
Re: air pump fuse?
the SES light is the service engine soon right? mayeb that is the reason i have been throwing the code.
ill just take it to the dealer and say i heard tehre was a recall on this particular part see what they can do for me.
if they cannot fix it then i have to ask where is the harness for the airpump located? is it right there at the end of the exhuast manifold or where?
thanks for the info
Old Jun 3, 2006 | 11:31 AM
Re: air pump fuse?
The electrical harness plugs into the body of the AIR pump, located at the front of the engine under coil/IC module:
Courtesy of Shoebox:
http://shbox.com/1/temp_sensor1.jpg
Old Jun 3, 2006 | 03:09 PM
jkucz31's Avatar
Re: air pump fuse?
i have plugs in my headers but my air pump is still running can i take out the fuse without throwing a code. i dont feel like getting the air system out of my computer yet
Old Jun 3, 2006 | 04:01 PM
Dave89IROC's Avatar
Re: air pump fuse?
pulling the fuse will set a code, however, leave the fuse in and just unplug the air pump, tada, no code
Old Jun 3, 2006 | 05:29 PM
onetransam4u2nv's Avatar
Re: air pump fuse?
weren't u the one that said when your fans comes on u get a ses light? Im almost sure mine did that like 3 yrs ago i read a article about it and it just said place a larger amp fuse. i did it and haven't had a prob
Old Jun 4, 2006 | 07:38 PM
nervekiler's Avatar
Re: air pump fuse?
well its already blowing a 20 amp fuse.. thats a decent size fuse in the first place to blow.
it blows immediately not like at random... so i think my problems are more than just too small of a fuse.
ill try unplugging the harness hopefully it wont give any bad sideeffects. and for the record its not the harness listed as the temp sensor the harness i need is actually on the air pump itself right? ill go check it out tonight.
Old Jun 4, 2006 | 08:25 PM
Dave89IROC's Avatar
Re: air pump fuse?
yes, It's on the pump, it is all the way to the right of that pic that was posted
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
cmdeshon
Dec 27, 2014 10:06 AM
