Air Pump Delete
Old Nov 27, 2004 | 09:35 AM
99Bird's Avatar
Air Pump Delete
Can I delete the air pump on a '97 without any adverse computer issues?
Old Nov 27, 2004 | 09:59 AM
GR8RIDE_96's Avatar
Re: Air Pump Delete
i got rid of mine on my '96Z, and didn't throw any codes or anything, also,a guy i know did it on his '97 formula and he had no trouble at all either. get rid of it.
Old Nov 27, 2004 | 11:09 AM
Birdman7389's Avatar
Re: Air Pump Delete
What would be the benefit of removing it?
Old Nov 27, 2004 | 11:11 AM
joshp007's Avatar
Re: Air Pump Delete
It cleans up the engine bay quite a bit. Get rid of the ugly tubes off the top of the manifolds. Just gives it a cleaner look imo
Old Nov 27, 2004 | 11:36 AM
96LT16SPD's Avatar
Re: Air Pump Delete
I was considering doing removing the AIR Pump also. I was just wanting to know what it actually did? Thanks.
Old Nov 27, 2004 | 01:02 PM
99Bird's Avatar
Re: Air Pump Delete
It feeds air to the exhaust system for the cats through the exhaust mainfolds...
Old Nov 27, 2004 | 02:16 PM
Loading's Avatar
Re: Air Pump Delete
Anyone got some instructions for doing this? (94 Trans Am)
Thanks!
Old Nov 27, 2004 | 02:24 PM
99Bird's Avatar
Re: Air Pump Delete
If you have stock exhaust manifolds it is not as easy as with headers. If you have the stock manifolds you will need to get a special sized bolt to thread into the manifold, I'll see about getting info on this for you. Basicallly you unbolt the air pump, which is located on the driver's side under the ignition coil and remove the air lines going to both manifolds and the air line to your intake. You must plug the intake after removal. There is a sold line that runs across the front side of block that you can remove too.
Old Nov 27, 2004 | 02:32 PM
Z95m6's Avatar
Re: Air Pump Delete
This is a good mod to do. It doesn't gain you any power but it does clean up the engine bay a good bit. It also makes waterpump, opti, and plug changes easier. Plug changes are only easier if you cut the metal tube out.
Old Nov 27, 2004 | 02:46 PM
dmoor88's Avatar
Re: Air Pump Delete
4-7lb reduction, that's about it
Old Nov 27, 2004 | 03:27 PM
94zgreenmachine's Avatar
Re: Air Pump Delete
I removed mine easy. After I unbolted 3 bolts and tried to get it off the bracket it just fell apart. It was so rusted up inside I highly doubt it worked to begin with. Oh, and by the way, the metal air tube is a pain to get out.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
armedtrigger
Feb 24, 2015 08:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
