air pump delete
Old Jul 5, 2004 | 01:28 PM
streetrat129's Avatar
air pump delete
Can someone tell me how to do this mod???
Old Jul 5, 2004 | 01:39 PM
Z95m6's Avatar
remove the air pump, plug the holes on the exhaust manifolds or headers if you have them. 94-95's have 22mm plugs 96-97 have diff size plugs that i don't know about. Thats pretty much it. If you want to you can cut and remove the metal air tube that is bent like a U and goes under the front side of the motor and comes up by the spark plugs. I believe if you do that though there is no easy way to put AIR back on the car for emission purposes. It does make getting the plug by the alternator a little easier to get to with the air tube out of the way.
Old Jul 5, 2004 | 01:51 PM
amean94ta's Avatar
easier way is to send your pcm to pcm for less and he can do it in 5 min and it still looks legal
Old Jul 5, 2004 | 01:56 PM
Z95m6's Avatar
for most people they do the AIR mod to clean up the engine bay, drop a couple of lbs, and make for some more working room.
Old Jul 5, 2004 | 02:14 PM
hambone3441's Avatar
anyone have some pics on doing this and part # for what they used to plug the holes. Thanks.
Old Jul 5, 2004 | 03:49 PM
eagleknight97's Avatar
Yeah, just getting it programmed out isnt a popular choice, because it does not hurt you in the least, so leaving it in, but programming it out, accomplishes nothing at all. Removing it on the other hand, makes the bay look cleaner, less cluttered, and removes a few pounds, thats about the only reason its done.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
armedtrigger
Feb 24, 2015 08:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
