air pump?
Old Feb 8, 2006 | 05:57 AM
95 FIREBIRD's Avatar
air pump?
if you take off the air pump on a 95 lt-1 does it make the engine run any diferrent or set off a code?
Old Feb 8, 2006 | 07:03 AM
94_Z28_guy's Avatar
Re: air pump?
As far as I know, as long as the fuse for the air pump (in the fuse box under the hood) is not blown, there should be no code set. As far as running different, it shouldn't, depends what you mean by 'take off the air pump' you'll have to plug up some stuff if you take 'everything' off.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
