Air Intake
Old Apr 8, 2004 | 06:55 PM
95Z28ConvertCam's Avatar
Question Air Intake
95 LT1
when installing your own ram air mod like this http://www.charm.net/~mchaney/ramair/ramair.htm
I dont see where the air is going to go with the box clamped shut thight will it still work or should I cut out the bottome of the stock box I dont want to wreck anything and I have the 9 X 6 hole out the bottom and the sheet metal ready to put in and with that box all sealed up Im not seeing were the air will go maybe Im wrong I need some expert advice that would help alot also what have you guys done??? thanks
Old Apr 8, 2004 | 07:08 PM
Question
sorry I forgot to ask would it also be ok maybe if I took off the air filter and put it back down there and not clamp the box shut so it would just have half the box in there???
Old Apr 8, 2004 | 08:12 PM
Caps94ZODG's Avatar
well it will help a stock air box..but I think its more for a cold air induction kit..the filter on the CAI is right in that place and I could see the advantage of doing it..I wanted to do this for some time..looks simple enough..just havnt had the time..anyone???
Old Apr 8, 2004 | 08:31 PM
yeah I could see it helping alot for the kit. that was my plan so when I got the kit I would already have it moded, so I would just pop it in. just wanted info if it was ok to use just the left side of the box with no air filter or use the whole thing and cut out the bottom of the box but nobody seems to know
Old Apr 8, 2004 | 08:46 PM
Bud M's Avatar
check my scoop pics, you'll see what to do.
http://f1.pg.photos.yahoo.com/ph/bud...ir+scoop+4.jpg
Old Apr 8, 2004 | 08:52 PM
yeah that helps, looks like a better that way cause it catches more by using the front air dam. it looks like. plus it has a better look to it. but do you know or what you did with the air box. or do you have a kit. duh never mind I see you kit I have stock right now and I was trying to think of a better way to use it. thanks for you pic looks nice
Old Apr 8, 2004 | 09:36 PM
magius231's Avatar
one of the free mods out there involves cutting the bottom of the stock airbox out...personally I would jus tmake my own PVC CAI for $60.
Old Apr 8, 2004 | 09:42 PM
how would you do that magius231 PVC CAI what would you need and how do you do it???
Old Apr 9, 2004 | 12:24 AM
so it wont hurt to cut the bottom off of stock box mag?
Old Apr 9, 2004 | 07:56 AM
race24x's Avatar
Hey guys I use my Z as a daily driver has anyone seen any issues with water from rain or whatever going up the ram air scoop and causing problems. My GSXR with the K&N filters hated the rain it ran like **** when it rained.
Old Apr 9, 2004 | 01:33 PM
I would like to know that too!
Old Apr 9, 2004 | 06:13 PM
race24x's Avatar
Does anyone have this mod and experienced any problems in rain ?????
Old Apr 9, 2004 | 08:01 PM
Bud M's Avatar
That's why I made a cover for my scoop
Old Apr 10, 2004 | 07:40 AM
race24x's Avatar
So there is a problem if you do not block it off in the rain ????
Old Apr 11, 2004 | 10:55 PM
Bud M's Avatar
I don't know, if its raining hard I cover it. It only takes me a few minutes.
