Air/Fuel Ratio Gauge
Old Mar 21, 2004 | 06:53 PM
OnefstCamaroZ28's Avatar
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
Ok, I just installed a Tranny Temp gauge and now I want to install a air/fuel ratio gauge in my dual gauge pod.
The red wire i connect to a fused and switched 12V positive source that is turned on and off with the ignition switch
The black wire I connect to an engine ground
The White wire i connect to dash lighting
The violet wire Im having trouble with - the directions say to "Connect to O2 sensor signal wire. Connect to vehicle wiring harness, not oxygen sensor since some oxygen sensors use sheilded wire."
Can anyone explain that better for me? Where is the O2 sensor?
Does anyon have a picture of it?
Thanks!
Old Mar 21, 2004 | 07:12 PM
1msfyter's Avatar
what year is your car? on my 95 I have only 2 O2's
On the passenger side , look down at the O2 grab the wire harness and follow it back. The purple wire is the wire you want tap into.
Old Mar 21, 2004 | 07:41 PM
Its a 96, does anyone have a picture of the O2 sensor so I know what im looking for.
Old Mar 21, 2004 | 08:21 PM
1msfyter's Avatar
http://www.fasterbaby.com/wire02.jpg
VERY easy to find
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
themex2002
Sep 2, 2015 03:47 PM
4586
Aug 13, 2015 10:11 PM
Aug 7, 2015 01:26 PM
