air foil?
Old Mar 23, 2004 | 06:08 PM
MeanZ687's Avatar
air foil?
does the air foil give enough power to be able to feel it?
Old Mar 23, 2004 | 06:12 PM
95z6spd's Avatar
I believe it does a lil at high rpm. It just smooths the airflow out a lil. I had one in my car for a while. Just installed a Holley 52mm throttle body. The airfoil is for sale.
Old Mar 23, 2004 | 06:20 PM
Kataklysm's Avatar
You won't notice anything.
Old Mar 23, 2004 | 06:41 PM
My95Z's Avatar
yeah, you won't feel anything. If you do, it is in your head
Old Mar 23, 2004 | 06:55 PM
Kataklysm's Avatar
I think its dyno proven to do just about nothing.
Old Mar 23, 2004 | 06:56 PM
AxeGrinder30thZ's Avatar
Old Mar 23, 2004 | 07:50 PM
"White Knight"'s Avatar
No idea, I did it when i did intake......so i felt something, but was from the intake.....it's just something you do cause it's cheap and helps throttle response a little
Old Mar 23, 2004 | 08:10 PM
Red96Lt1's Avatar
I think the dyno says it will give you about 1 hp
Old Mar 23, 2004 | 08:41 PM
HardcoreRM125's Avatar
In the Xmas JEGS cataloh, it has one in there ... Heres what it says ...
pg 186 TPI/LT1/LS1
Throttle Body Airfoils
TPIS ~ Better throttle response, an 11.8 horsepower increase and 36 more CFM. Installs in less than 10 minutes and has a lifetime guarentee. 59.99
Everyone on here says its NO gain though. So thats probly false advertising ??? Or there are other variables that they let out (Like dyno on 90* day, put in air foil, and Dyno on 40* day)
Old Mar 23, 2004 | 08:52 PM
Then again, its also made to fit the TPI engines too, not just LT1's, So maybe they pick up 11.1 and LT1's get 1 or 2 ???
Old Mar 23, 2004 | 09:20 PM
CamaroSS30thAnn's Avatar
Old Mar 23, 2004 | 09:24 PM
Robs97Z28's Avatar
It is dyno proven to make Hp, some where around 11 hp. Will you feel 11 hp, my guess is no. IMO, as you put on bolt on like, cai, elbow, maf and larger tb's. you probably would see a much higher #.. just my 2 cents...
Old Mar 23, 2004 | 09:25 PM
SantaCruz163's Avatar
On Horsepower TV one of the guys actually installed an Airfoil in a Impala SS LT1 and there were no gains. I think the airfoil costs ~$40 so I defentely think it's a waste of money. I could spend that money of something more useful.
Old Mar 23, 2004 | 09:29 PM
CamaroBoy96Z28's Avatar
Airfoils are overpriced by $30-$50. No way they should cost more than $10. All the above posts are right, any claim in power gain is . Spend your money on something actually worth it.
Old Mar 23, 2004 | 10:05 PM
NOMAD's Avatar
http://www.ws6.com/mod-4.htm
They are worth $10-15, but no more honestly. I'm working on my own line of them as we speak. As soon as I get moved, expect some pretty interesting projects coming from Halbert Performance
-Shannon
