air and egr
Old Mar 25, 2008 | 06:16 PM
andrew ws6's Avatar
air and egr
what will it efect if I have them deleted in a tune
Old Mar 25, 2008 | 06:52 PM
dangalla's Avatar
deleting the air will affect tailpipe emissions as it helps the cat burn raw fuel
edit: if the egr is tuned out it should not cause knock, the reason for knock is because the pcm advances timing when egr is actuated
Old Mar 25, 2008 | 10:34 PM
Lack of EGR can cause knock. The EGR reduces high combustion temps that can lead to preignition.
Old Mar 26, 2008 | 10:09 AM
96supersport's Avatar
AIR only runs when the car is cold started or when the coolant temp goes below a certain temp.
It also runs randomly for system checks.
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Jan 13, 2015 09:19 PM
97SSdude
Dec 31, 2014 07:43 PM
Mykdiver
Aug 13, 2002 05:38 AM
