!AIR! delete
Old Feb 3, 2003 | 10:27 PM
94z'sson's Avatar
!AIR! delete
does anyone know how to delete the air pump and not have a fault code
Old Feb 3, 2003 | 10:29 PM
BPS's Avatar
BPS
on a '94 - just unplug it
Old Feb 3, 2003 | 10:37 PM
94z'sson's Avatar
what about the rubber lines and the ones that run to the exhaust
Old Feb 3, 2003 | 10:49 PM
BPS's Avatar
BPS
removing an air pump on a '94 will not result in any codes - unplug and remove the unit, remove the lines and put the proper sized bolts into the exhaust to preven a massice leak.
Old Feb 3, 2003 | 10:55 PM
97WRAITH's Avatar
No ses in my 97' either.
Old Feb 3, 2003 | 11:00 PM
94z'sson's Avatar
ok thanks for your help i will unplug it
Old Feb 3, 2003 | 11:48 PM
auslandt's Avatar
What is the benefit of removing the AIR pump? Other than being able to get the FREEKING WATER PUMP OUT! (sorry bad weekend).
Old Feb 3, 2003 | 11:53 PM
turbo_Z's Avatar
i removed mine simply b/c i thought it was an eye sore. theres no performance gain whatsoever.
Old Feb 4, 2003 | 12:37 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
air pump? say what? where?
Old Feb 4, 2003 | 12:41 AM
1msfyter's Avatar
It fell off my car last week... I went to napa and spend the money on the correct plugs(22mm) No codes more room and looks cleaner.
http://www.bealer.org/plug.jpg
Old Feb 4, 2003 | 10:15 AM
auslandt's Avatar
What is the AIR pump for? Does it just add more oxygen into the exhaust so the cat can do it's job better?
Old Feb 4, 2003 | 10:24 AM
Bryan Smith's Avatar
Look Ma' No pump
Old Feb 4, 2003 | 11:28 AM
JAFO1994's Avatar
Air pump runs for a few minutes on start up to heat your cats up. If your doing headers, it makes it easier to rip the AIR, along with the EGR stuff off and cap everything. I had to cut the bottom crossover pipe on the AIR with a dremel in two spots to get it out. There's no performance gain, except more room and you don't have to worry about an EGR going bad or getting plugged.
DirtyDaveW
Dec 1, 2016 05:37 PM
HarleyZ28
Oct 5, 2015 06:23 AM
armedtrigger
Feb 24, 2015 08:30 PM
95chwagon
Jan 13, 2015 09:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
