Air Conditioning Rattle
Got a rattle from what sounds like under the car when the air is on up middle to floored throttle. Only happens when the air is on. No loss of power, no trans slip nothing. Only happens when the air is on. Thoughts?
Re: Air Conditioning Rattle
Just Kidding, its probably a worn out Compressor.
Edit: O yea or a bad belt tensioner....
Yea I was thinking the Belt tensioner too. I'll have to check it out today. I get alittle belt slippage when coming off full throttle. Might have fubared it when I got the cam swap done. I'll check it out. THanks for the insight.
One other thing to look for could be a dirty IAC. When the A/C flips on it should rev up a little. If not revving up high enough then this could be the problem. I'm assuming you have an A4. A lot of A4s have idling issues with the A/C on. What are your RPMs at when you have it on versus off?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Richardan15
May 30, 2015 08:36 AM
95chwagon
Jan 13, 2015 09:19 PM
squarehead
Nov 21, 2014 08:02 PM
