Air Bag light after LT install
Old Aug 25, 2003 | 09:18 PM
CrippleFightin's Avatar
OK my Air Bag light is on. I cant figure out why. I just got done installing my Jet-Hots yesterday. Anyone help me out here?
Old Aug 25, 2003 | 11:21 PM
Lyle A's Avatar
Did you check the fuse for it?
Old Aug 25, 2003 | 11:22 PM
Transamdriver's Avatar
Mines been on for over a year.
Old Aug 25, 2003 | 11:30 PM
Lyle A's Avatar
There is an extensive troubleshooting sequence in the GM manual. It would be too much too list here. The fuse should be the first step. There are also several trouble codes that will tell you what the cause is.
Old Aug 25, 2003 | 11:31 PM
6Speed's Avatar
Did you disconnect your steering to put the headers in? There is a sensor somewhere in there, that if the steering wheel is allowed to spin 360 degrees, will break.
Old Aug 25, 2003 | 11:55 PM
Shayne's Avatar
I just finished a head and cam swap and my air bag light is now on. I know my steering wheel was turned more then 360* so that sensor you talked about is more then likly broke. Has any one fixed this problem?
Old Aug 26, 2003 | 12:03 AM
Lyle A's Avatar
All I know is that the airbag system is trickey. Make sure you disconnect power to it before you service anything on it.
squarehead
Jan 15, 2015 07:02 PM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
