Air bag light on after engine install
Old Aug 26, 2009 | 08:07 AM
JC95Z's Avatar
Just noticed that my air bag light is on after dropping the k member out.Any ideas? Im going to check the wires out today and make sure nothing is pinched or cut but other wise clueless.
Old Aug 26, 2009 | 11:57 AM
dangalla's Avatar
while your at it get it scanned so the code can lead you in the right direction - i think autozone will do it for free
Old Aug 26, 2009 | 02:25 PM
JC95Z's Avatar
I scanned it at work just now and it doesnt pull any codes?Also i didnt see anything wrong with the wires or sensor.
Old Aug 26, 2009 | 02:32 PM
belac350's Avatar
Did you turn the sterring wheel when you removed the k-member? if you did you broke the clock spring for the air bag. You can get one used, easy to replace
Old Aug 26, 2009 | 10:05 PM
JC95Z's Avatar
Actually yes I did and I even heard something break but thought nothing of it.Guess I'll be stoping by the salvage yard.Thanks for your help.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
