AIR BAG light
Old May 24, 2003 | 06:40 PM
Rodrigues's Avatar
AIR BAG light
My air bag light is constantly illuminated and I have no idea why. There is so many variables because it has been doing it since I did my ported heads and cam as well as reprogrammed the PCM that came from a caprice. Any ideas? The caprice PCM has the same pn that the camaro one had and I changed the programming on it.
Old May 24, 2003 | 06:53 PM
madwolf's Avatar
The PCM has nothing to do with the airbag light. (which is controlled by the BCM - Body Control Module)
Is this the only light you're getting or some other cluster funkyness? (jumping RPM, flashing lights, ABS light, etc)
Old May 24, 2003 | 06:58 PM
Rodrigues's Avatar
Just the Air Bag light, thats it. I think I know why too, I just read that if you spin the steering wheel while the steering columb is removed it can ruin the steering coil. I couldn't resist spinning it and it looks like it will cost me $107 and a lot of labor.
Will my air bags still deploy even though the coil is broken?
Also while I was searching I found that after shops install hooker lts that people have the same problem, atleast I am not the only one who couldn't resist spinning the steering wheel
Old May 24, 2003 | 07:02 PM
madwolf's Avatar
I did cam/LTs installs and never had such a problem before.
Find a used SIR coil and replace it. See what happens.
Removing the steering wheel is not that complicated and the coil is right there.
I am not sure if your bags will work right with a bad SIR. (if it's even bad that is. You should get your BCM codes scanned and see exactly what it's throwing)
OR, you could always remove the AIR BAG light pin from the BCM connector and you're done.
Old May 24, 2003 | 07:19 PM
Rodrigues's Avatar
ill go check the codes right now....
Old May 24, 2003 | 07:20 PM
madwolf's Avatar
Not the PCM codes but the BCM codes. It's not the same thing. You have to use one of those dealership scantools to get to those. (there may be some other method too. ask shoebox )
Old May 24, 2003 | 07:49 PM
Rodrigues's Avatar
I went out to check the BCM codes, not the PCM codes madwolf.
Usually you can check the codes through the security light. The procedure for this is:
Turn key to on position
Turn key to off posiition
Remove radio fuse
Turn key to ACC position
Within 1 second return back to off position
within 5 seconds return back to ACC position
Read codes from security light.
Ive done this to my brothers 96 before but its not working on mym 95. Can anyone here look up the procedure for the 95?
Old May 24, 2003 | 08:11 PM
Rodrigues's Avatar
That would explain it!
Originally posted by Killerjello
ummmm..... the 95 doesnt have a BCM i dont think, at least mine doesnt, they started using them in 96......
Old May 24, 2003 | 08:20 PM
Walkovaya's Avatar
the airbags will not deploy as long as that light is on...or at least they shouldnt
Old May 24, 2003 | 10:53 PM
Right. You have no BCM (you have a DERM) and the air bags will not deploy when the light is on because it is indicating a failure in the system. Yeah, if you spun the wheel, you ripped the leads off the SIR coil.
BTW, the air bags are controlled by the DERM on the 1996 as well, not the BCM.
DERM=Diagnostic Energy Reserve Module
Old May 24, 2003 | 11:33 PM
Timberwolf's Avatar
you could just do what I did with the airbags, sensors, steering wheel, the whole works... SELL EM
no need to replace the SIR coil then and you can get a nice wheel for less than the $107 you'll have into that thing...
dale3in98
Feb 14, 2015 12:18 PM
rwferguson43026
Feb 6, 2015 10:06 AM
Airplanedoc
Feb 1, 2015 07:14 PM
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
