AI H/C track times.....
Old Apr 7, 2008 | 03:34 PM
TravisA's Avatar
Ran my car yesterday and had a best of 11.48@118.3 in the 1/4 and a best of 7.34@95.98 in the 1/8th. Short times were 1.73-1.75 on those runs.
I'm still running a 3.23 gear which I think was hurting the car especially through the 1/4. The car would shift into 3rd right after the 1/8th and the rpms would drop to around 4500 and only pull to about 5200 through the traps. I was still pretty pleased with it for the first time out and think the car will run 11.oh's with a gear change.
*edit*
Heres a video of one of my passes. Ran 7.38 1/8th and 11.51 1/4 on this video with a 1.76 60ft.
http://s69.photobucket.com/albums/i5...t=travisa2.flv
Old Apr 7, 2008 | 03:45 PM
onebadponcho's Avatar
I wonder if there will be a pool going on how long it takes for this to be an AI vs. LE thread?
Seriously, nice times. Changing to 3.73/3.90/4.10/4.11 gears should definitely help your 60'/ET.
Old Apr 7, 2008 | 03:52 PM
TravisA's Avatar
Thanks!
Lets hope it doesn't turn that way. I would rather hear opinions on how much a gear change would help.
Old Apr 7, 2008 | 04:00 PM
speed_demon24's Avatar
FWIW when my only changes were 3.73's and the crane 227 cam (only gained 19rwhp) I went from 13.0 to 12.5. The tranny was slipping on the 12.5 run as well. I gained 6mph too. I don't see bottom 11's/high 10's being a problem with a better 60' and 4.11's.
Old Apr 7, 2008 | 04:30 PM
lt1junkie's Avatar
Good times!!! will be sure to post up my times N/A once i get the car to the track for LE H/C i am curious how close they will be.. What kind of RWHP are we talking or have you not had it on the dyno?
Old Apr 7, 2008 | 05:44 PM
NightTrain66's Avatar
good times.
I would think just getting the 60 fts down in the 1.60 range will get you in the 7.0 range.
More gear "should' get you in the 6.90 range.
Lloyd
Old Apr 7, 2008 | 06:22 PM
MEAN LT1's Avatar
Good times mam, keep om pushing.
Old Apr 7, 2008 | 06:34 PM
mad95z's Avatar
Nice times! More Gear would Help.
Old Apr 7, 2008 | 06:36 PM
SS MPSTR's Avatar
Ditto on the gear opinion. I'd likely stick to a 3.73 though...
Old Apr 7, 2008 | 06:41 PM
flyinZ's Avatar
Nice ET's..Id stick with 3:73's, unless you dont drive it much. If you dont, drop it down to 4:10's
Old Apr 7, 2008 | 06:54 PM
dangalla's Avatar
very nice man. bet thats fun to drive, good luck with it
Old Apr 7, 2008 | 07:16 PM
TravisA's Avatar
Thanks guys!
I'll be throwing a 3.73 in it real soon.
Old Apr 7, 2008 | 07:25 PM
mdacton's Avatar
Old Apr 7, 2008 | 09:25 PM
TravisA's Avatar
Video added to original post and yes the hatch is open for some reason..haha
Old Apr 7, 2008 | 09:26 PM
Wow you can really hear it fall on its face on the 2-3 shift. Is the converter locking up? I'de say low 11's shouldn't be a problem with more gear and a better launch.
