Ahhhh, the money pit
Old May 13, 2005 | 08:23 PM
jpack24's Avatar
Well went up to the corner gas station. Went in and came out, click click no start. $50.00 tow home. Checked battery, good. Checked neutral saftey switch, starter solenoid disengages going into drive. Well, here is the question, if it is V.A.T.S., would the stater solenoid click? If it is not V.A.T.S., then I guess I need a new starter. What do you think?
Old May 13, 2005 | 08:32 PM
92/95TransAm's Avatar
Re: Ahhhh, the money pit
the starter solenoid should not click with the vats being bad atleast none of mine ever have. i would asume the starter. try tapping on it with a screwdriver handle or lightly with the handle of a hammer. wouldnt bang on it really hard though and be careful not to arc anything
Old May 13, 2005 | 10:22 PM
beretta1101's Avatar
my 96 z has done this to me 2x. both times it was cold outside just clicked clicked. these 2 times were 1 and a half years apart too. i just tried starting it later in the day when it was warmer and vroom right up it started.
good luck
Old May 14, 2005 | 08:37 PM
Thomash's Avatar
How did you check the battery? Did you try to jump start it? Are the battery cables clean & tight? Both Ends?
If the answer to the last three are yes, I'd say its the starter.
Old May 15, 2005 | 09:09 AM
jpack24's Avatar
good luck
Well same thing here, went out and figured, ah what the heck, i'll try it. Damn thing started right up.
93 RedBird
Nov 15, 2015 08:24 AM
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
NewsBot
Sep 30, 2015 04:20 PM
