Ahhh yes, another timing chain thread...
Old Apr 19, 2004 | 11:15 PM
Hawk350's Avatar
Okay fellas, I have done my research here on this board. I have a 94 non-vented opti and will be installing heads and cam hopefully this weekend. My timing options are limited. Many guys here are claiming that they have slack in their stock timing chains. Cloyes says this: "Oversized LT1 Steel crankshaft gear- Have you noticed your used or your new timing chain are very loose when installing your new cam? (well, it will be) We offer this oversized gear to tighten it up which allows more precise cam timing. It is made from steel instead of powdered metal. Offered for both LT1 OEM chains and the GM HD roller chain sets." So.... I am thinking that I will get a stock timing chain and this oversized gear to remove the slack....this should work fine for a 400hp application. Any suggestions? And yes....I have looked into a opti swap....$700 is not worth it.....that's how much the parts cost from gmpartsdirect.com. I rather replace the timing set every few years than spend 700 bucks. I only drive the car apprx 5k each year anyways. any suggestions? comments?
Old Apr 19, 2004 | 11:26 PM
ARRFormula's Avatar
I went with the stock timing set on mine. I dont see any problems on it, running 400 hp or less.
True, you gotta change to the vented opti set up to get the strong dbl roller and such.
Cloyes sells a stronger than stock timing set-up for the non vented opti for like $400....I think it's stronger than the stock setup...but I have no idea. Most people just switch over to the OBDII FWIK
Old Apr 19, 2004 | 11:34 PM
Hawk350's Avatar
I know, I checked the cloyes website....400 is alot of $$$ though...I am convinced that teh stock will hold just fine with the oversized sprocket. I dont plan on running my car everyday and the track maybe 3 or 4 times a year....stock is stronger than everyone makes them out to be...or from what I have been reading here on the site.
Old Apr 20, 2004 | 12:06 AM
RicocheT's Avatar
I was considering using the cloyes for 92-94 timing setup. Who sells the stock set with an oversized crankshaft gear I may look into that also.
Old Apr 20, 2004 | 12:25 AM
Hawk350's Avatar
Check this out: The oversized gear on this page.
http://www.moreperformanceinc.com/timgchn.htm
Old Apr 20, 2004 | 12:46 AM
turbo_Z's Avatar
you could switch to 95+ opti and timing cover... then buy an electric waterpump. b/c youd have an electric pump then you could run a regular SBC cloyes... for the 87+ hydro-rollers and they only cost around $80.
Old Apr 20, 2004 | 06:39 AM
Hawk350's Avatar
95+ opti = $700 for parts....not an option. Already looked on ebay and everywhere else...400rwhp should be fine with the stocker...
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
