AHHH. Car died in rush hour! Is it my fuel pump?
Old Apr 7, 2006 | 09:02 PM
ss6ixspeed's Avatar
Problem solved... fuel pump went out. Thanks for the help.
Old Apr 7, 2006 | 11:51 PM
OBE1 95Z28's Avatar
Re: AHHH. Car died in rush hour! Is it my fuel pump?
Could be fuel or ignition. Need to see if you have fuel pressure and spark.
Old Apr 8, 2006 | 12:14 AM
ss6ixspeed's Avatar
Problem solved, thanks for the help.
Old Apr 8, 2006 | 03:00 AM
RedLT4Mike's Avatar
Maybe your ICM got SUPER heatsoaked from the high heat conditions.
It's super cheap, you may want to start there.. That is my shot in the
dark without speaking with you, and knowing your car.
Old Apr 8, 2006 | 03:20 AM
87lt1rx7's Avatar
with my experience with elctric fuel pumps, you might be able to have someone bang on the gas tank while you are cranking it over and it might start. I have used this method to identify a bad fuel pump on some saturns and misc. other cars
Old Apr 8, 2006 | 07:30 AM
The only way to determine a fuel pressure issue is to put a pressure test gauge on it. That eliminates all the guessing.
Old Apr 8, 2006 | 08:17 AM
BlackScreaminMachine's Avatar
Pressure guage, do Key on Engine off, see how it looks 40-45 psi, if its able to be driven, try putting it under load and see if it drops.
Old Apr 14, 2006 | 09:29 PM
ss6ixspeed's Avatar
Just an update. It was the fuel pump. No warning what so ever... just dead. Only 65,000 miles on the car, never driven hard and never raced. Replaced it with a granatelli direct fit and am very happy with it. The guy I had do it said it dropped right in. Perfect fit. He replaced it the right way... dropped the tank, exhaust, suspension, etc and did a very fine job. This coming from a critic. His shop is near St. Louis and I highly recommend him for any f-body work needed. 2 guys run the shop and do great business... check them out, www.redline-fbody.com
ANDYZ28
Dec 29, 2014 09:13 PM
CaRParts102
Dec 6, 2014 08:45 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
Skull Leader
Aug 10, 2002 11:01 AM
